Originally Posted by Zumba I bought a solid carbide spotting drill to get through the tough shell of some case hardened steel shafting - 60rc.
It worked fine in the beginning, but now the bit has dulled after only 20-25 holes. At $25 for the bit, that's $1.00 per hole.... not worth it.
What's happening is that it requires a lot of downforce to get the cutting going. The bit sits there spinning for awhile, not moving down at all. I'm arm is hanging on the quill lever. Then suddenly the quill plunges down a few thou and smokes the bit. That's probably what dulled it in the first place. I have flood coolant going but it just sizzles while the heat builds up.
How much pressure should be required to spot drill hardened steel? I'm thinking about installing a stepper motor on the quill of my mill and running it at something ridiculously slow like .020"/min. I don't have the hand control to move the quill that slowly. Maybe I should use the knee?
In any case, I have to use the BP clone for this operation because some of the shafts I'm drilling are 8ft long. Might be time to convert the manual mill to CNC.... |
how many pieces? how fast spindle etc.
