  #10
Old 08-21-2006, 04:22 PM
MrBean's Avatar
MrBean MrBean is offline
Gold Member
MrBean is on a distinguished road
Originally Posted by PsyKotyk
The results are very impressive. What kind of spindle speeds are we talking? Like 3000-5000, 10,000-15,000 or higher? What's the size of the mill bit, or since it's conical, is it just as pointy as it can be?
Hi. I would say the spindle was running in the region of 25,000 rpm
And, yes the cutter is pretty much as pointy as you could make it.
The widest part you can see of the shaft is 3mm, the thinner part is 2mm.
Picture attached below...
