I had another problem this week that resulted in srapping the part. I thought it was the same old cutter comp problem, but turned out to be a new problem. I was rough cutting a slot with a 1.25 shell mill when it tried to cut through the wall of the slot. I checked the tool path and all looked good. When I looked at the screen on the bridgeport I noticed the prev, current and next line of code. The current code was out of order. The machine had lost its place at picked out a random line. Replaced the part and hit Run and it cut perfect. |
