Originally Posted by Ron111 tppjr,
Good piece of work. For some reason I could not get to your second link, but could be on my end.
What motor did you add to increase your spindle speed? Maybe you had a thread to you did this in? I guess my general question would be should people that increase their spindle speeds above the nominal 2000 rpm for the RF-45 mills expect excessive bearing heat?
Anyway, from your first link, I can tell you that I'm impressed with your ability to first define the problem and to engineer the solution!!!!!!!!
Good Job and I will try to visit your second link in the am to see your manifold system.
Thanks for sharing your work,
Ron |
Ron,
Thanks. First, if you make it to any of the links go to the top and there is a drop down that will allow you to go to any of the others from there.
My RF is a true RF and is the way it came from the factory. It is the 220/3 ph 2 speed model. High speed in High gear is 3k. I don't know if they make it anymore but that is what I have.
