R/C motor cases for spindles: if you replace the bearings with decent ABEC 7's, they should run pretty true. Unless you're real carefult however, spindle alignment may become an issue.
Some of the cases are pretty flimsy - especially those with cut out cans for mag field tweaking. You might be better off simply machining a case from seamless tubing, especially with regard to stiffness. |
