New xyz data point file after decentration | | I am trying to locate a program or someone wanting to make such a program that will allow a .txt data point surface file rear surface to be moved from 1 to 6 mm relative to a spherical front surface. These files are 80mm x 80mm with and have 13,140 lines of x,y,z data. X and Y are in 1mm increments. The front surface is spherical and this back surface must be relative to the radius of the sphere 1 to 6mm and then the correct new x, y and z data captured or calculated. The new grid would be at least 68mm x 68mm. The size would be reduced by the amount of decentration desired.
Anyone interested in this brain teaser? |
