Can anyone help with a parts source? | | Hey all,
I am retroing a series 2, and I am having trouble finding a good supplier(s).
I need the following, (if you respond would you be willing to give manufacutrer and part #)?
1). a 50,000 mf or greater Cap, 150v or higher for the power supply.
2). a bleed resistor that can handle the above cap.
3). I would like to use a Thermresistor for the primary side of my transformers, to help on the inrush, but I dont know how to size them or where to get them. I have 220v on the primaries, and 70v and 40A on the secondaries.
4). bridge rectifier, 600+V, and 50+ amps
5). Has anyone found any good deals on "Glass Scales" liner encouders? I had priced them from Newell, and acurite for 0.001 resolution but the ranges for all three was from $1,300.00-$1,800.00.......rediculously out of my price range, if you don't know of any that is ok, I will go with the old tried and true servo mounted encouders.
6). Does anyone have an extra Boss 6 series 2 maintanance manual they wouldnt mind parting with. I priced one from bridgeport and they wanted 125.00, and the Manuals dot com only has them on CD, (I would prefer paper/manual). The reason is, the rear electrical cabnet is still intact, I would like the schematics on it, so I can see what I can re-use and what I can throw away. (note the entire Boss 6 control is gone).
I am currently using Rutex drives and servos/Mach3
Thanks in advance,
scott |
