Old 08-14-2006, 11:40 PM
tobyaxis's Avatar
tobyaxis tobyaxis is offline
Moderator
tobyaxis is on a distinguished road
Originally Posted by MichaelHenry
From what I can tell, Tormach limits the feed rate and rapid speed to 65 ipm, which makes it a bit slow for large production runs as each part will take longer to make than it would on the more mainstream CNC mills, which apparently can feed and rapid at much higher speeds (200 ipm?).
The thought is that the part design and CAM time for prototypes and short runs will take the bulk of the overall part production time and that faster mill speeds are not cost effective in that context. This is all covered to some extent in the mill design document available on Tormach's web site.
I'm a hobbyist and the feature set should be just about right for me, so I just placed an order and should have the mill in about 6 weeks.
Mike
The 200+ Rapids for Production on New CNC's is around 1200-2800 IPM depending on the travels of the machine and the distance to be traveled.
Ex. A CNC Swisss Screw Machine has Gang Type tooling on both sides of the guide bushing and a travel in the X/Y of 1.5 inches. The Rapids are around 800 IPM. Very Fast.
As a suggestion if I may, the Tormach seems to me like a Tough Little CNC Mill that should do well cutting Steel. As a note you can get production out of the Tormach with a little method I like to Call "Raising the Z". If you were to place a 2" inch thick block under your vise or fixture you reduce the amount of travel in the Z axis. This means the Z has less of a distance to travel, hence a slightly lower cycle time and less wear-n-tear on the Z axis Ball Screw.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
