Old 08-10-2006, 12:07 PM
widgitmaster's Avatar
widgitmaster widgitmaster is offline
Gold Member
widgitmaster is on a distinguished road
Cool This is how it was done before CNC!!!
First I started with a chunk of round cast iron, because it is soft, east to machine and strong!
I faced both sides in my lathe and turned 1/2 the diameter until it was complete.
Then i bored and counterbored a hole in the center to accept a 1/2" diameter shoulder bolt with .75" long shank, making sure the head was slightly below the surface. The bore was a close slip fit for the shoulder bolt.
Then I grabbed another chunk of cast iron, and machined it to 3"x1.25x.750
Then I drilled a shallow hole in the center of the .750 wide side, 3/8 in from the end. Then I bottom tapped the hole for 3/8-16 UNC, to accept the thread on the end of the shoulder screw!
Then I drilled and tapped a 1/4-20 UNC hole in the other end of the cast iron block to be used by the handle.
Next, I took the cast iron disk and machined two flats 1/2" deep on the counterbore side, leaving a 3" wide parallel surface to be used when clamping it in the vise.
Next, I calculated the distance for the stop pins, as .375" + .125" =.500
Thats half the .740 block and half the pin. then I moved X-axis .75 on either side of center, and Y-axis .500 to drill anad ream two slight press fit holes for standard dowel pins.
Once the block was fastened to the disk with the shoulder blot, I dialed the disk in one more time and drilled & reamed a press fit hole in the rotating block for a 1/18" dowel pin. Drilling it after assembly ensures the 1/8 dowel will be exactly in the center of rotation!
Then I grabbed a 1/2 dia x 3" piece of 303-SS and drilled & tapped the ends for 1/4-20 UNC, then I ran a piece of 1/4-20 threaded rod in until it jammed tight in the bottom of the holes, and bandsawed off the excess, leaving a 1/2" of useable thread!
One end screwed into a little 1" dia plastic ball-knob, the other screwed into the rotating cast iron block.
then i made a little block from scrap cast iron, to be a clamp which holds my little parts on the pin in the slot on top of the rotating block!
I put the fixture in my mill vise, dialed in center, and again calculated the offset for the cutter. The cutter is a 5/32 dia 4-flute carbide endmill, so the offset is radius + (1/2 cutter diameter)
ID:	20872   Click image for larger version
ID:	20873   Click image for larger version
ID:	20874   Click image for larger version
ID:	20876   Click image for larger version
ID:	20877   Click image for larger version
ID:	20878   Click image for larger version
