Originally Posted by DrStein99 ...I went to radio shack and found a 4-wire telephone "detangler" device. I believe it will do the job; however - looks kinda cheap and flimsy. As long as I can push 5-12volts thru this I'll be in good shape. |
It is not the voltage, phone lines run higher than 12 volts, it is the current that is limiting. Chances are you will be fine because LED currents are in the same region or maybe lower than phone line currents.
