Old 08-05-2006, 02:01 AM
itsme's Avatar
itsme itsme is offline
itsme is on a distinguished road
Hi there,
I don't have experience with the EAS drivers, but I can probably help a bit with some of the other stuff.
That board should be fine for those steppers. You should be able to limit the current to 2A and then overdrive the steppers all the way to 40 or 50 volts. My steppers are rated at 4.5 volts and I run them at 40V. This is limited by the driver that I use. There is a ballpark figure floating around for how much to overdrive your steppers, but I can't remember it and I'm not going to guess. Anyone?
I don't know the different wiring methods off-hand either, but it is no problem to wire 6 or 8 wire motors in a 4 wire configuration. Quite straightforward.
Regards
Warren
Have a nice day...
