Thread: fanuc HSM
Old 12-31-2003, 10:36 AM
Scott_bob's Avatar
Scott_bob Scott_bob is offline
Mfg Engineer
Scott_bob is on a distinguished road
Jeremy,
That's my son's name. Is your Komo a router or a milling machine?
Either way, have you checked out this issue:
http://www.cnczone.com/showthread.ph...5&pagenumber=3
Want to test your machines BPT?
It sounds to me like you machine is not fast enough to process the data points or motion codes your program is formated in.
Are the programs big?
Are you loading the program in the machine memory?
Is the code linear (point to point) or does it have G2 & G3 codes?
There is an awsome solution for you. Are you busy enough to go for it?
Sincerely,
Scott_bob
Scott_bob
