Old 12-30-2003, 06:13 PM
thuffner3's Avatar
thuffner3 thuffner3 is offline
Gold Member
thuffner3 is on a distinguished road
What do I need to do with what I have?
Imformation overload, Homebrew CNC
(Post #1 )
Ok, now that I've been throughly (much by my own doing) drown in imformation.
Ok, This is where I'm at right now. (Things are working, or at least moving in a linear fashion).
I'm using this controller,
http://www.stepper3.com/31.htm
I'm using these three motors,
http://cgi.ebay.com/ws/eBayISAPI.dl...item=2582180840
I've hooked into the +lines 1 ohm resistors(no idea what the watts are).
PSU, is standard older ATX 300 watt.
I'm running KCAM4.0. (Have noted, I should use TurboCNC).
on a Win98 system p166 -w- 32 mg ram standard laptop.
I was noticing some flatness on circles, say larger than 3" dia.
This flatness occurred on the x-axis.
(I was told this could be caused from a machine/mechanical problem).
Check system, Same type x-axis configuration as y-axis.
(would think flatness would occur in both directions if mechanical).
Check motors, x-axis motor seemed to be really light in the torgue area.
(this was while running KCAM4.0).
Tried TurboCNC, the torgue output was there for the x-axis but seemed to stutter somewhat.)
??Idea's??
I downloaded the resistor calculator. If my controller has "FETS"
my motors require 5.00 ohm /7.2 watt resistors.
If my controller has resistors. my motors require 4.25 ohm/6.12 watt resistors.
FETS and RESISTORS are alien to me. as are the watts for the motor power resistors.
Can I find the required power riesistors given the info above?
And do I have a decent setup for a homebrew system?
Thank you much in advance for any input.
