Old 12-30-2003, 02:50 PM
DJ Morrow DJ Morrow is offline
DJ Morrow is on a distinguished road
Caution building with MDF
I'm still new around here and am going to start by building a small router from Crankorgan's plans. I was doing some reading on using MDF and found the following which I think is worth reading by anyone else who might be using it. Although there is not much to be cut, I may just switch to a top quality plywood instead ( which also contains glue ).
http://www.design-technology.org/mdf.htm
" Disadvantages: -MDF can be dangerous to use if the correct safety precautions are not taken. MDF contains a substance called urea formaldehyde, which may be released from the material through cutting and sanding. Urea formaldehyde may cause irritation to the eyes and lungs. Proper ventilation is required when using it and facemasks are needed when sanding or cutting MDF with machinery. The dust produced when machining MDF is very dangerous. Masks and goggles should always be worn at all times. Due to the fact that MDF contains a great deal of glue the cutting edges of your tools will blunt very quickly. MDF can be fixed together with screws and nails but the material may split if care is not taken. If you are screwing, the screws should not be any further than 25mm in from the edge. When using screws always use pilot holes. Urea formaldehyde is always being slowly released from the surface of MDF. When painting it is good idea to coat the whole of the product in order to seal in the urea formaldehyde. Wax and oil finishes may be used as finishes but they are less effective at sealing in the urea formaldehyde "
David J. Morrow
