Thread: Moglice
  #11
Old 04-22-2003, 09:38 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Could still be tricky in the narrow confines of a nut, where the thickness of the injection is only going to be .007 to .015. I'd be surprised if the bond is super strong to the one surface, and yet provides clearance on the other. It is very difficult to even clean a nut to be chemically clean enough to provide a good bond without some kind of acid etch. Then to also provide a non contaminating release agent on the screw, and get it into position without contaminating the interior of the nut would be miraculous.
I think that for the method to work, you'd almost have to saw the top half off the nut, then bolt it back down for the duration of the procedure, then open it up to release the screw again.
But, anyway, we'll sit and wait for the play by play.
