Old 07-31-2006, 07:38 AM
xyz100 xyz100 is offline
xyz100 is on a distinguished road
Steppers are not controled by voltage. They are controlled by current. Stepper spec. (if you manage to get one) would specify current per phase. Now, most stepper controllers have capability to limit phase current at required level. This level is set by means of reference voltage applied to the controller (trim pot on the board). Threfore the controller will see a reference voltage and will know what the stepper current should be.
