Rapid to (# set by Parameter) What's yours? | | During G83 peck drilling rapid motion returns to +____
This positive distance from the last feed depth is set by a parameter on your Fanuc control.
#532 on an OM control
This parameter is set by most factorys at 1000
or .100 thousands
That is way too much if you are drilling with small drills.
Smaller drills are programmed at lower feeds and the time wasted, feeding thru air can really add up.
If you do much drilling at all, check this setting...
Before you do, get a cycle time of commonly drilled holes and see how much time you'll end up saving, you'll be amazed!
I think this setting should be set at 200
or .020 thousands
or 100 (.010)
The Fadal control uses a P_ value to set this distance in the G83 line of code.
Fadal default is zero. This means that Rapid motion returns to the last peck depth. I believe a little clearance here is best in the event of a chip falling back in the hole... I use P.010
Scott_bob |
