Thread: Encoder wiring
Old 12-28-2003, 06:31 PM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is offline
Eric, I would not think it was the encoder at this stage, especially if the error is repeatable, the 50 thou error I suspect may be due to backlash?
If you use an encoder cable with independant pairs, it is customary to use a twisted pair for the A,/A & B,/B pair etc
The shield should only be grounded at one end, Usually the amp input end as this is usually closer to the main cabinet gnd.
Due to noise problems I had on one installation, I have been using belden 9891, I believe this is an ethernet cable, but it has one pair which is larger than the other conductors which I use for the power pair. I have had no problems since with any of the retrofits I have done.
Is your encoder on the motor or on the final motion actuator, i.e. ball screw or slide?
Al
