So is that what "Optimized" means to you, shorter cycle? To some people it means shorter program (less code).
Edgecam offers a number of cutting styles and I usually run one style and then check the cycle time. Then pick the other style and then compare.
You can also sort (Rationalize) toolpaths in a number of ways to reduce cycle time.
The real time savings with a cam system is whan you get an engineering change to a part that's alread been programmed. Re-programming it in Edgecam is a snap. Re-doing a manual program can be much more time consuming. So that depends if you ever get enginering changes to you parts
As for less code, Edgecam will also create subroutines to reduce the amount of code. So the same drilled pattern on several faces will be put into a sub.
Mike Mattera
