I know what it is geezz I thought I was dumb to , (just kidding) I did a search and what it is, is
Moglice FL/P Formulation Date 1988 - is a fluid with a consistency similar to gear oil. It can be injected or poured to produce way systems, quill bores, nuts or tapers. It is also used in the pour and set application technique.
Moglice P-500 Formulation Date 1986 - is a slightly thicker fluid with a consistency similar to honey. It is still injectable and is often used in ball nut applications, air bearings and in the production of sub-micron accurate bores.
Moglice 628 Formulation Date 1985- is a semi fluid having the consistency of a thin putty and tends to run on a vertical surface with minimal damming required, but will not run off a flat way. It is most commonly used on machines with large flat ways because it is easier to mix, apply and get the component down and aligned.
Moglice Putty Hard Formulation Date 1983 - is a no-slump putty and is the most common material used on standard way systems. It can be applied to vertical or overhead surfaces without running or dripping.
Moglice 1000 Fluid is a fluid about the same viscosity as the Moglice P-500 above. Moglice 1000 Fluid differs in that it contains Teflon and results in a 25% to 30% further reduction in friction. It also provides added protection against moisture absorption.
Here is the website -
http://www.moglice.com/
