Old 07-21-2006, 02:40 PM
js530 js530 is offline
js530 is on a distinguished road
The HF suppression caps are rated .047uf 1600 vdc, 900 vac with 5 parallel sets of two in series, giving a .235 uf 1800 vac bank of capacitors. Secondaries are ~22 volts, using around 20 turns of 16 ga plastic insulated (non magnet wire, much cheaper) wire. The tank cap is around 30 of the same .047uf caps in series.
I'm pretty sure I need a better power control circuit than what I have, so the details on that will come later.
