Originally Posted by panozeng Al - I would definitely be interested in the name of that valve you found. With the bender's current on/off solenoid she stops quite violently at higher bend speeds. l. |
I will try and find it, it has been a while, the other thing that some do with on/off type valves is when the end approaches, there is a paralell flow control solenoid kicks in for the last few degrees for slow approach, the catch is that you need the feedback or a settable limit switch to detect the correct point to slow down.
