Al - I would definitely be interested in the name of that valve you found. With the bender's current on/off solenoid she stops quite violently at higher bend speeds. In fact, I am going to have to anchor this machine to the floor - it walks the opposite end from the bend arm about 1/2" every time you hit the stop at middle to high bend rates! It has no current provision to be mounted, so I'll have to add some tabs. Actually might make a frame for it to sit in that has levelling feet as well. |
