Yes,
A real closed loop system, closes the loop back to the software. You would need to have encoder feedback to tell the "real" position of each axes. This feed back is sent to the software to compair what it thinks the position is and what the real position is. Adjustments are made by the software if needed.
You need to find step and direction controller software that had the closed loop inputs.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
