Old 07-19-2006, 10:19 PM
NC Cams NC Cams is offline
NC Cams is on a distinguished road
If you are wiring capable, build it. If you are electrnically challenged, buy it and learn how to run it AS IS.
You can always upgrade it later when/if you see the need...
The hard part is getting something to run. Don't add the complexity of re-engineering something if you don't have to...
Why?
If/when it doesn't work, was it because of bad design (easy to do) or bad parts (possible as well) or poor execution (possible and most probable either way you go)???
