You think you can control Bender? Ha!
On the serious side:
Originally Posted by panozeng One axis would be a linear feed. One a rotation angle. And the last variable is bend angle which involves switching a hydraulic solenoid on until the rotary encoder reached the desired bend angle. I guess this could be done as an axis? |
Is there a control for reverse? Maybe you could output the step and dir pins for the "bending" axis to a PLC, and if the dir pin was high and the step was pulsing it would go forward. If the dir pin was low and step pulsing it would reverse.
Nikolas
