Programming for angle head--G18/G19 | | I am a new user to this group and I like the questions/responses/dialogue that gets posted, so I joined.
I am using v7.x and trying to figure out the easiest way to program an angle head on a W axis ram (large HBM). The angle head is manually rotated when it is to be indexed and I want to use G18/G19 for milling and drilling. I just started the programming and currently trying to switch the coordinate systems around to match the machining surface (head pointing X +/-, Y +/-)and I am not rotating any geometry. When I render the part the tool motion does not look correct but when I post the program the G-code looks ok. I do have a Gibbs post for the angle head but will be writing my own as needed using Posthaste.
Am I going about the programming correct or is there an easier way?
Dave |
