We get this with our router sometimes, due to rounding errors I think. I usually change the endpoint in the g-code by a very small amount (.01mm) and it will usually correct it. Probably not an option for you. If you're using R arcs, switch to I, J arcs and it should go away.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
