Old 07-10-2006, 03:51 PM
jcoats's Avatar
jcoats jcoats is offline
jcoats is on a distinguished road
I have loaded it, and was able to get it started and use it a little on a Linux and a Windows machine (XP Pro), but I am still learning to use CAD so really cann't say much pro or con.
The windows was easy to install, and for Linux, I did a source install on an UBUNTU system (untar the package and read the INSTALL file. ... In the end it is basicaly a standard: configure, make, make test, make install senario, really easy).
Now, I want to generate g-code for my home HobbyCNC setup. From BRL-CAD what would I do to do that? Save as a DXF, then dxf2gcode?
I also would like to generate STL (3d lithograph file), to run on a REPRAP (see reprap.org - basically a homebrew 3d lithography machine). Any idea how to export to STL?
Thanks ... Jack
