Read the PostHaste Formatting Reference Manual, then find a template that posts something close to what you want. Rename the template and start editing. You might find an existing template in the library that is almost an exact match. PostHaste is pretty easy to work with and can be made to do some complex post processing. Unless you find someone who will give you a Gibbs post, this will be your alternative. You should be able to get the basics down fairly quickly and start posting in no time. |
