So what have you got, 200 steps at 90:1? That should give you 18,000 steps per 360 degrees rotation.
That works out to 50 steps per degree.
So perhaps if you define one inch as 50 steps, then you will get a display of 360 for one revolution.
Your maximum command resolution for the table would be .02 degree per step.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
