^^ I measured the shop and it is 45' not 50' so thats a plus. I will use it move granite slabs around, from the cart to the saw and so on. Maybe my 3K lbs estimate is a little high. The slabs weight is 1,200lbs. max plus the winch, trolly, vacuum lifter, I think that will be another ~700lbs. So I think a better estimate would be 2,200 lbs. max load. This load will mostly be in the middle.
I can make the trolly support wheels farther apart to spread the load. If I happen to need to move something heavier i'll just use the forklift. With the over head crain one person can move the material around.
__________________ Dennis |
