Built my first cnc machine last summer (a jrgo with a Xylotex controller, and 269oz steppers) I decided it was time to upgrade to a bigger machine, a bigger power supply and new controllers.
First step was to figure out how to build a new power supply without killing myself. After a lot of reading and then more reading I built a 55Vdc 15Amp supply, with Gecko 202’s and a cnc4pc interface board.
I went a little over kill on the cabinet; I installed four 100cfm fans (2 blowing in 2 blowing out). The cabinet is 30X16X6 inches and weights a ton with everything in it. I also made the cabinet so it’ll hang on the wall. It makes it a lot easier to get at things this way.
Putting the power supply together went pretty smoothly. Once I figured out what I needed and what hooked up where it was easy. I designed the front panel and all the cutouts, and a clamp for the capacitor in VCarve Wizard (Great software, and they’ve got a new version out that really rocks!
www.vectric.com)
So I hooked the power supply up to my current machine. With my old setup I could cut (if I was pushing it) around 25ipm. With this new supply I can cut around 100ipm and get rapids around 140ipm. I’ve got a trim router on my current machine so I think if I did any serious cutting I’d slow things down a bit. But man is it cool to see that thing fly after cutting at 15ipm most of the time.
I’m going to take a ton of pictures of this build. My last build I thought I took a lot of pictures but looking back it wasn’t near enough.
