Old 07-04-2006, 08:09 PM
Kiwi Kiwi is offline
Kiwi is on a distinguished road
The angle of the tooth (deg.) is 360 divided by the number of teeth.
The 6,8,10,12 pitch relate to the size of the tooth.
Once you have decided what tooth size you require and the number of teeth this will determine the diameter of your gear.
When cutting with a dividing head you do not need to worry about the angle, just calculate the number of turns and holes on the appropiate plate.
