  #12   Ban this user!
Old 07-03-2006, 07:40 AM
FPV_GTp FPV_GTp is offline
FPV_GTp is on a distinguished road
hi
midiguy732 , i come across this skate_bearing rail setup some where of the net
alot more maching required , but if someone is thinhking of making a larger plasma or router table needing more support for ridgity under the mail rails this could be a simple solution
less bearings one side so only three bearings hug the mail rail allowing for a bridge arrangment so the skate_bearings( ballscrew ) doesnt hit the mail rail supporting feet .
I'm sure even with ur setup midiguy732 , one could leave out one side of the bearings and fit on the ends of both sides a U - shaped bracket and drill and tap holes and screw them to the ends of the skate_bearing for extra ridgity so they dont flex apart from the rail .
see what u think guys/
ID:	19501   Click image for larger version
