Old 06-27-2006, 08:24 PM
MetLHead's Avatar
MetLHead MetLHead is offline
Gold Member
MetLHead is on a distinguished road
Hi Dave,
The G28 should work just like you described. The commanded axes first move to the commanded position, then move to the machine zero point. You can set NCPlot to show G00 moves as non-interpolated. This is on the machine configuration dialog on the control options tab. The only thing not supported is the tool offsets. Did you try the new beta? Let me know if you see something that doesn't work.
Thanks,
Scott
