Old 12-15-2003, 10:50 AM
HomeCNC's Avatar
HomeCNC HomeCNC is offline
HomeCNC is on a distinguished road
He will never reach that kind of RPM! When you place an encoder on them your fastest you can go will be determined by the computer sending steps to the driver!
Be leary of high RPM motors. This is where the 1/8HP is taken from and you will never get there using it as a servo motor. My servo motors can take 20 amps peak. and turn only 1750 RPM max. Higher amps is better for strength.
Jeff Davis (HomeCNC)
http://www.homecnc.info
