You can wire them bipolar series and get full rated torque at low rpm's. Or, wire them parallel, and run them at 2.5a and you'll get less torque at low rpm, but you may get more torque at higher rpm. You'd really have to do some tests on the parallel wiring. Bottom line is they will work fine with the xylotex wired in series, and produce the full rated torque. Be aware, though, that the torque will fall off faster when wired in series.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
