I'm wondering if any1 could tell me if
it would be strong enough for a tube with
1/16 wall to be tapped. It will be holding
a thk rail with a dozen CBored hole.
I got me a table, with 1" melamine( I plan on adding 3/4 MDF on top of it),
but the frame is 1-3/4 and 1/16 wall, it seems perfect, for my application.
I just need to put a lot of braces
Should I just use longer bolt then nuts,
the rail is not tapped, but needs M4 to get thru.
I've started my build with a footprint of 30"x30".
it will be used as an plexiglass cutter/engraver,
but will try to push it harder maybe cut 1/8 thick aluminum.(just maybe).
thanks.
