Old 06-19-2006, 06:10 PM
TMaster TMaster is offline
TMaster is on a distinguished road
Im in the process of hooking up 3 home switches on my Taig.
Durring normal operation is the curcuit closed having the voltage/reistance though the wiring and when it gets to the home position the switch opens so there is no circuit?
Or is The other way around where The circuit is open durring normal operation, and when it gets to the home positions the switch make the circuit closed/powered?
VCC and GND terminals on the Xylotex board with the 10k ohm resitors? I have the newer 4 axis board with P pins labeled.
Im going to be using the X home, and Y home, Z home, selections in mach3. Do i activate the Active low buttons too?
This is confusing. I need a a total made diagram. lol
