speaking of spindle speed control is there a way with the xylotex controller to connect it to you're spindle supply via relay or something so that you can Call a M03 and turn on the spindle with the program vs. doing it all manually. I just thought it would be a trick feature to have on the machine I'm planning on building in the near future. As far as having speed control what determines the speed at which the spindle turns at, Volts? I'm not sure on a lot of this stuff but I'm learning as I go along. |
