Old 06-18-2006, 02:03 PM
andy55 andy55 is offline
andy55 is on a distinguished road
Originally Posted by imf
Ahh, that is probably why folks do it directly in hardware, eh?
Yes, if you wire a quadrature encoder to the parallell port and read it as fast as possible with EMC you can probably get count rates of 10 kHz, maybe 50 kHz.
Hardware encoder counters can do 0.5 - 1 MHz or more.
with a hardware encoder counter, EMC then reads the encoder counter value each time the PID loop is calculated, every 1 kHz or maybe 10 kHz.
The actual signal is 24 bit, 90khz so I probably could get the raw position kinda fast, but the latency on serial link might be a bit much. What we do on PWM channels with shaft encoders though is go real fast until we're nearing the end of our travel and slow down logarithmically until we get where we want.
Granted, this probably isn't something for high-end machines. At the very least, I guess (if you have an old computer laying around) it is an easy way to get DRO on your mill.
A cheap DRO is certainly possible.
Encoder counter hardware is not that expensive, the Mesa electronics m5i20 card which has up to 8 encoder counters and 4 axis motion + lots of IO bits is around 200usd.
