Thread: Servo Motor
Old 06-17-2006, 12:17 PM
Ed Williams Ed Williams is offline
Ed Williams is on a distinguished road
Servo Motor
I asked this under servo motors with no replies so I thouht I would ask here. I was wondering if these motors would work on 2x3 table. The gantry weights 120lbs. It has thk bearings and ball screws. It has 5tpi screws. I was going to use 2 to 1 pulleys.
Thanks Ed
Globe PN (custom): 537A-214
Frame Size: Nema 23 (non-square mounts though)
Static Torque: 190 oz-in
No Load Speed: 4504 RPM
Max Bus Voltage: 42 VDC
Max Continuous Current: 3.4 Amps
Peak Stall Current: 6.7 Amps
Shaft Diameter: 0.25"
Encoder: HP 1024 PPR Optical Disc Encoder
