Old 06-17-2006, 10:09 AM
WayneC WayneC is offline
WayneC is on a distinguished road
Installing linear guides
I'm getting very close to upgrading (read rebuilding) my Shopbot with new linear guides. I don't want to redo the rack and pinion stuff, just install new improved guides onto the unistrut stuff.
I use the Shopbot, a 120x60 inch with stepper motor with a Porter Cable router, to cut pine, cabinet plywood, and sign foam. The current stepper motors/controller, etc are adequate, and will probably remain. This is just a rails upgrade. Shopbot claims .015 accuracy, and I'd be happy with that, but would like to get better if I can.
Some questions:
1) Any comments between the HIWIN guides (20 mm?) versus the lo-pro wheel guides from Bishop Wisecarver? They are in a similar price range. Any obvious advantage/disadvantage to either?
2) How do you install these rails accurately. I'm a woodworker, so I can use a tape measure. But how do you set rails both parallel and straight across a 60" + width within a few thousands? Is that sort of accuracy required?
3) My thinking is to install the wheel rails vertically, and place the gantry load on the radial axis of the wheels. If I use the HiWin, I'm thinking I should mount the rail horizontal, but I don't have a clear technical reason.
Thanks for your input- this is a tremendous resource!
Wayne from White Salmon
