Help? First attempt at building CNC table | | My intention is to build clocks and other gear driven devices...to this end I need only a 2D machine with a relatively small capacity. My material will always be a plywood or laminated material, and in the neighborhood of 1/8" or thinner.
I've scanned over the archives, and found that small motors like the rotozip provide enough power to mill simple materials like wood, given a sharp router bit.
Now. Going through what materials I already have available to me, I realized that I have an old HP pen plotter capable of handling 8.5" wide paper, through legal size. (HP7470A)
Essentially, isn't this already a 2D CNC machine? Modifying it to take the additional thickness of plywood, rather than paper, would seem to be trivial, and the cutter head could be mounted on a flex shaft, with the motor "suspended" over the original plotter, which would eliminate its weight as a factor.
My concern is about the drag caused by the cutter head. It would be tremendous, compared to a felt tipped pen on paper, which is what this machine was designed to handle. Would this present a problem? Or do plotters have a means to measure the distance actually travelled?
Basically I want to know if I can do a conversion, or if starting from scratch would be a better choice?
Thanks ahead of time for any input you can provide. I have a feeling that it's going to be a LOT of help in the near future.
-- Chuck Knight |
