I assume that the benzine mentioned in the poll means benzene. The two spellings are often used interchangeably although benzine with the 'i' is really a totally different solvent.
If the people who clicked on benzine are really using benzene the percentage is small but higher than it should be. Because the should be level is zero!!!
For those using benzine or benzene you should find out exactly which it is, do some Googling and find some msds information.
Benzine, if that is what is really being used is not that bad; it is not much different to gasoline or naphtha.
Benzene is a very bad carcinogen and there is really no reason why it should be used at all as a solvent where human exposure is possible. |
