Old 06-12-2006, 07:02 AM
gar gar is offline
gar is on a distinguished road
060612-0656 EST USA
tobyaxis:
I believe that Enshu may have an option that you can purchase to upgrade from 9600 to 38,400. If you do mold work and drip feed this could be advantages.
The HAAS 3.5 floppy connects thru a parallel connection and does not use RS232. To compare transfer rates create a valid file about 50,000 bytes. Time the transfer of this file from floppy and thru RS232 at whatever desired baud rate. Then calculate bytes per second for each method.
