Old 06-11-2006, 03:55 PM
daedalus daedalus is offline
daedalus is on a distinguished road
You are probably aware of this, but just to make clear, the transformers are rated in AC volts, which is not the same as the final dc voltage you get out of the powersupply after you rectify and smooth this AC voltage. If you want 25VDC out then you dont want to be buying a 25VAC transformer. If your unsure about any of this i suggest you do a good search of the forums before buying anything, as this has been covered many times.
