Old 06-11-2006, 10:30 AM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
For that kind of work, you'll need to run your control in single step mode, I suspect. One push of the run button would execute one line of code.
To do the same thing in automatic (continuous run) mode, you would need to insert an M00 between each axis movement command. If you can access your machine post setup, you can perhaps find a way to insert an M00 after each G01 and G00 movement.
