Old 06-10-2006, 05:41 PM
radicooldude radicooldude is offline
radicooldude is on a distinguished road
Hi, I am the designer of the mounts. I had they custom made by someone. There are no "known" suppliers, but I and going to try and make them my self on my sieg x1 in the next week or so. I'll report how they do. After the design was made, I relized a few problems. Its an easy fix though... The bottom edge of the bearing block needs to be cut up about 3-4mm to provide enough spacing to clear the castings, so you get the full travel on the x and y axis. I will fix this problem, and gladly send you the design in either autocad, solidworks, or via a jpg with dimentions if you would like. I'll keep you updated. - Zachery
